C452- Machine making a loud noise non stop
  • jsr_777
    replied
    Re: C452- Machine making a loud noise non stop
    Originally posted by Synthohol
    take a look at the bottom gear circled, usually the axle (hole) wears out and the gears make a racket as they sloppily mesh.
    Thanks I will definitely check those out.
  • Synthohol
    replied
  • Arcadian
    replied
    Originally posted by blazebusiness
    My guess would be either the Eject drive unit (affordable $60) if you are lucky
    Or the Fuser Unit Assembly (not cheap / around $650) if you are not so lucky.
    Meter reading on the copier?
    Fuser is easy to remove and you can inspect it to see if it turns smoothly
    The eject drive unit white gears wear out frequently and cause weird wrinkling,noise,jamming
    Call a tech and have it diagnosed properly and hopefully you won't need the fuser.
    dont have to buy a whole fuser can buy parts like bearing gears and rollers, but you still need a tech, or someone who knows how to take thing apart and knows what to look for.
    ive seen tech who says they are tech, dont know what the hell they are doing, even Qualified ones, they just go by the book, when the book should be burned!!!
    but sounds like a bearing i had rollers go bad, one time found an extra roller inside the intermediate transfer unit, with NO bearing in them! the last tech did not installed the bearings!!
    wow!
    Well good luck.
    If you cant trust a tech then who can you trust!!
  • blazebusiness
    replied
    Originally posted by jsr_777
    https://photos.app.goo.gl/y7CDqCdoijqtX4KM9
    I'm working on a Konica Minolta Bizhub C452, and its making loud noises nonstop, when powered on. There are no errors, but when i try to make a copy the paper either jams, or comes out very hot and crimped. Any help with this issue would be greatly appreciated. If you click the link, I attached a video so you can hear the noise.
    replied
    Funny ... I'm not getting any audio, but I don't think I need any. From what you've said the fuser is the place to start. If you don't know what a fuser is, it's time to hire a copier technician. =^..^=
    I second that emotion!
  • jsr_777
    replied
    Thanks, that was my first guess but I wanted to get some 2nd opinions before i spent the money on it.
    replied
  • jsr_777
    started a topic C452- Machine making a loud noise non stop
