Konica c284 toner problem
  • lucycopy
    • Jan 2019
    • 22
    good morning,
    I have a problem with a konica c284 I changed the toner BK and the copier remains to do the upload until you tell me that the toner is used up.
    I tried to change DV but the same thing.
    what may it have ever happened to you?
  • E-ring
    • Apr 2019
    • 10
    Re: Konica c284 toner problem
    Hi,
    there is a turning mechanism on the bottle, it is driven by the hopper unit on the inside/backside. Check if the bottle is being turned by the hopper unit by making a mark on the bottle wheel that turns.
    • lucycopy
      • Jan 2019
      • 22
      Originally posted by E-ring
      Hi,
      everything runs perfectly
      the tcr sensor gives me 0
      • E-ring
        • Apr 2019
        • 10
        There is one gear in the subhopper unit that drives loose, so toner is not transported.
        • allan
          RTFM!!
          • 5450
          Happens when the grid arch to the drum. It will empty the entire bottle into the tank with utter disregard for the TCR value and with no error code!. Replace with a original dev tank and drum unit at the same time.
          Don't ask me why that is but had this a couple of times and only on black.
          Could also be be the relay board infront.
          Sure you don't get an error code?
          Whatever
          • copyman
            Owner / Technician
            • Sep 2005
            • 4313
            This happens a lot with aftermarket toners & developer.
            • lucycopy
              • Jan 2019
              • 22
              thank you so much doing so it is broken down
              good allan
              • allan
                RTFM!!
                • 5450
                Life on these machines are a lot better with original toner.
                Whatever
                • allan
                  RTFM!!
                  • 5450
                  good allan
                  On startup you will get TCR at 0% if you get 0% and the colors have a value you could have a different problem.
                  Whatever
                    • 22755
                    It is not uncommon to have these white bushings/seals on the hopper pack with toner and stall the toner drive. If you remove the engine cove and watch the bottle drive you can see the affected color chatter and vibrate but not rotate. It's better to remove the hopper. Remove the front bushing and vacuum out the first hopper and clean the impacted toner from the bushing. Remember there is a rubber seal in there, don't damage it. Re-assemble first hopper. Repeat x3:
                    It is unnecessary to refill the hopper. It will refill itself in about 3 seconds. You can watch depleted developer tone back up in less than 1 minute. =^..^=
