How do you see drum and dev Life on C458 ?
  • omada
    • May 2019
    • 2
    [Misc] How do you see drum and dev Life on C458 ?
    Hello all,
    Please I need help to find access at the life level of other consummable that toner (drum, dev, transfert belt ... )?
    Some weeks that I search on the main panel of my C458 ... I have also service access but nothing ...
    Many thanks in advance
  • Synthohol
    Certified Konica Expert
    • 5737
    Re: How do you see drum and dev Life on C458 ?
    Software switch 227 change hex to 00 hit fix.
    • omada
      • May 2019
      • 2
      Thank you for your quick reply Synthohol ! Could you give me more detail please ? This is firmware update ? or if you have detailled procedure ?
      • tsbservice
        Field tech
        • 7911
        He gave you everything you need IF you are tech.
        If enduser with access to tech mode, you shouldn't mess with the things you don't understand.
        May end up with good boat anchor instead of machine.
        BTW, what's wrong with your C458?
