prints scratching bizhub c350
  • Scottyj
    • Jun 2010
    • 17
    [Misc] prints scratching bizhub c350
    Hi all,
    Hope someone can help here.
    I have a bizhub c350 and I am getting scratches in the print and non-print areas (see attached).
    It may unrelated but I am also getting some sort of repeat marking (also see attached in the red and blue shirt)
    I have cleaned all intake rollers with alcohol, the transfer belt and LPA assembly.
    appreciate any help
  • qbert69
    • Mar 2013
    • 1152
    Re: prints scratching bizhub c350
    Originally posted by Scottyj
    Hi all,
    appreciate any help
    What is the condition of your fuser??? Look for any toner buildup at the point of entry that the paper goes in. Also check the fuser exit.
    Sent from my SM-N950U1 using Tapatalk
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
    • copyman
      Owner / Technician
      • Sep 2005
      • 4543
      Looks like transfer belt to me.
        • 22943
        What is the repetitive interval? 96mm? =^..^=
        • Scottyj
          • Jun 2010
          • 17
          Removed and checked fuser unit - found some debris in between rollers which had scored the rubber roller - cleaned everything down with alcohol. (pretty confident this was the issue)
          replaced unit - tested and scratches were still present.
          Repetitive interval - 125mm
          transfer belt removed and cleaned with alcohol.
          may have to start replacing parts
          • copyman
            Owner / Technician
            • Sep 2005
            • 4543
            Start with replacing the transfer belt
            • Scottyj
              • Jun 2010
              • 17
              I will give it a go, thanks for info
                • 22943
                The 125mm points to the fuser. =^..^=
