Konica Minolta Bizhub 350 Touch Screen Not Working
  • b837d
    • Sep 2019
    • 3
    Hi Everyone, new member here but been a lurker for a while.
    Sorry about the title, I know there are many many results on here with the same title, and I assure you I've read them all lol.
    A client of mine recently acquired a used BizHub 350 all in one printer. Its an obvious old unit that I have no experience with, but it seemed to work great for the first week or two. Then the touch screen stopped responding altogether.
    After lurking through post after post on here, as well as days of Google searching, everything seemed to point to the digitizer - seems to be a common failure point. So we ordered a replacement, installed it and still no response. Some suggestions were to do a screen calibration however from what I read (press microswitch to reset, when dot shows up on left of screen press #3, enter the code and press end) I get stuck on the "press end" because the screen is unresponsive.
    I'm at a bit of a loss here - is there something straight forward I'm missing, or is this thing just ready for the dump?
  • JR2ALTA
    • Feb 2010
    • 2033
    Re: Konica Minolta Bizhub 350 Touch Screen Not Working
    You should've installed a thin glass with a small ribbon cable on the right hand side. I have accidentally installed these upside down resulting in total loss of touch response.
    • Toxic
      • 697
      If you have no response at all then calibration will not work because you have to press specific area mark to calibrate.
      Maybe you installed digitizer wrong way like JR2ALTA said,you can see that by looking ribbon cable contacts and contacts in connector on board is it fit like it should or that digitizer is DOA (dead on arrival)
      • b837d
        • Sep 2019
        • 3
        You are correct, the thin glass with the ribbon cable is what I installed. I tried it both ways thinking that i may have put it in the wrong way but didnt seem to make a difference. Do you know for sure how to tell which way its supposed to go?
        I did try both ways and it didnt work either way. Don't think I can see the contacts in the connector on the board, its just a pull out style connector. I also cant see it being a DOA digitizer, as this is the second new one we've tried now, from two different sources. Im thinking - unless Im not hooking up the digitizer right - that the problem has to be elsewhere then... the question is where lol
        • jwai
          • May 2018
          • 508
          This is the common issue on this model.
          • b837d
            • Sep 2019
            • 3
            Yeah it certainly seems to be. This is unique, i think, in the fact that I've replaced the touch portion of the screen already but its still not working :S
            • Synthohol
              Certified Konica Expert
              • Mar 2016
              • 5824
              [.02]june 2017 was the end of support date for that model, no parts, no support, bupkiss.
              time to upgrade!!
              how can you support it if the manufacturer wont?
              [/.02]
              • Toxic
                • 697
                Did you clean good place where digitizer sits and frame around?
                If digitizer is pressed by something anywhere on surface it wont work because its one touch digitizer.
                One time i almost replace good digitizer because one small piece of some crap get between digitizer and plastic frame and digitizer wont work at all till i remove that and clean.
                Other solutions is to find complete control panel from scrap yard or take that machine to scrap yard.
                • Hansoon
                  • Sep 2007
                  • 3385
                  The "glassy" surface should face inside machine. The "plastic foily" surface faces the operator.
                  Hans
                  • Nicoabd
                    • Jun 2020
                    • 2
