C454e "TPM chip has been changed"
  • @ndy
    • Oct 2022
    • 7
    #76
    Good afternoon. Can i ask a question please? What key words should i write on kiku knowledge database in order to download MFPB Reset Tool? Thanks in advance ...
    • Duplicator
      • May 2022
      • 245
      #77
      None.
      As far as I know there are 3 ways to get it:
      • Konica only seems to give them out if you call support and convince them you need it.
      • Become a site contributor and convince someone here that you need it.
      • Contact copier tech or visit his website http://www.copierfirmware.co.uk/
      Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
      If I helped you out, please give me a thumbs up! It helps my reputation.
      • tsbservice
        Field tech
        • 8016
        #78
        So why?
        • @ndy
          • Oct 2022
          • 7
          #79
          So why?
          Good morning, its because i just want to be as much "updated" as i can. Maybe i will never need to use it, but i want to have it.
          • Jumping Jack Flash
            • Jul 2009
            • 66
            #80
            You just want it and that's it?
            And that will be all?
            Will you say thank you and it's done?
            • @ndy
              • Oct 2022
              • 7
              #81
              Yes, yes, and yes ...
              Edit: Finally after many hours of search (and much more luck), i finally managed to download the relevant xxxxxx.tar file. Thank you all once more ...
                • Jul 2009
                • 66
                #82
                heh, I already like you
                If you have a need and reason to use this tool, I will send it to you via private e-mail
                • @ndy
                  • Oct 2022
                  • 7
                  #83
                  Thank you very much. I 'll keep in mind if i need something, although i pray not to be needed to me 😊...
