KM 601
  • Synaux
    • Mar 2012
    • 1224
    #16
    Re: KM 601
    Originally posted by allan
    There is an issue on the developer tank where there is to much resistance between the dev bias contact and the mag roller thru the bearings.
    Easily confirmed with a tester the resistance should be less than 50ohm.
    I use a piece of spring wire to run again the mag roller shaft that gets fixed behind a screw on the plate receiving the bias.
    That will get the resistance down close to zero, and should stop toner flying off of the roller. But if done with too much tension it will cut the shaft.
    I used a paperclip twisted around the shaft to...I have lost the photo, but if I have more energy tomorrow I will dig through my posts and add to this.
    Those switches change the speed the mag roller runs at to control density (only Konica could come up with a shitty idea like that).
    I do not recall that explanation in the docs--good stuffs!
    If you do single shot copies on this machine its not going to be fun. They like to do 150K print or more a month to be happy.
    [/QUOTE]
    When they run, they run. I was very disappointed--in a sense--when everyone seems to have gotten rid of them. Nowadays, Konica seems think it is wise to repurpose color MFPs for mono (aka without the color IUs--basically). I have a handful of clients (I am working in a different field now) that opted for the color versions just for the functionality. Just more unnecessary complications...and arguably weaker engines--in a sense...
