Bizhub C6500 - Code C-3801, TEMS/1 temperature suddenly drops after random time
  • mariuscmr
    • Apr 2017
    • 13
    Hello,
    I have an issue with my printer which I could diagnose only by monitoring sensors output.
    After a random amount of time (sometimes 5 minutes, last time 27 minutes), in fusing unit, temperature recorded on TEMS/1 suddenly drops in half and the machine stops.
    I checked / cleaned all four temperature sensors and all 3 thermostats (heater and pressure). Nothing helps. I was afraid to swap TEMS/1 with TEMS/2 because I wasn't sure they are the same, although they look the same.
    I really suspect the TEMS/1 to be the faulty one, but I need to be more sure. Can anyone advise me please?
    I recorded the moment when temperature drops, here is the link:
  • Toxic
    • 691
    Re: Bizhub C6500 - Code C-3801, TEMS/1 temperature suddenly drops after random time
    That is not rare problem on that machines,i always have 1 spare sensor for them.
    Both sensors are the same,different is just wires length from sensor to connector.
    I am almost sure new sensor will solve your problem.
    Only once i have that error and it was not sensor problem, it was paper betwean sensor and fusing belt so sensor could not read properly.
    • methogod
      • Dec 2008
      • 915
      replace sensor short of a wire being broken, would replace sensor.
