Konica Minolta C300i - excessive toner consumption
  • rolls.bo
    • Sep 2014
    • 42
    #16
    Re: Konica Minolta C300i - excessive toner consumption
    Hi everyone, I recommend updating the FW, here in Italy the E9 version is available, certainly not bad
    • Haaland
      • Mar 2009
      • 20
      #17
      Sorry for the late answer, the MML is at the link here: MML.rar - Google Drive
      I checked our demo machine (C300i) and TCR is at 7.0 to 7.2 on colors, and 6.36 at black, so now im starting to think TCR over HV-board...
      I checked for the E9 firmware, but its not out in Norway yet, might be able to get the firmware, but probably not with Norwegian language.
      Would you mind sending the release note? always curious what's new =)
      • Haaland
        • Mar 2009
        • 20
        #18
        I didn't find E9 firmware, but i found G00-D0, released two days ago.
        • tsbservice
          Field tech
          • 8016
          #19
          From reading your MML it appears machine had several errors leading to CPU and BASE boards. Moreover your machine has made incredible amount of stabilizations and they do eat toner. Our machine with double counter of your has Stabilization,Processing time,,57 and yours Stabilization,Processing time,,5614.
          Maybe faulty temp/humidity sensor false readings lead machine to perform stabilizations over and over. Check readings from service mode.
          • allan
            RTFM!!
            • 5462
            #20
            Did you get your info for toners used from the management list?
            On the list you will find new article detection for the toners.
            Is this a contract machine with toners included?
            High coverage prints?
            Toner does not need to go thru the machine to vanish.
            Whatever
            • rolls.bo
              • Sep 2014
              • 42
              #21
              search BT2012139EN I don't have the English version but in Italian.
              The document talks about the problem with the temperature sensor that can give various problems, maybe it can concern you
              • allan
                RTFM!!
                • 5462
                #22
                Do you mean the environmental sensor?
                Wonder what the prints must look like or rather feel like staked with that much toner.
                Or the waste box must be filling up at a pace.
                Whatever
                • rolls.bo
                  • Sep 2014
                  • 42
                  #23
                  yes the temperature sensor .............. if in:
                  Service Mode / State confirmation / Temp / Humidity / Atmospheric pressure.
                  the temperature is zero replace the temperature sensor
                  • tsbservice
                    Field tech
                    • 8016
                    #24
                    My guess based on MML lists was that his machine was doing so many image stabilizations which in turn slowly but constantly empty toners right into WTB. My first action on such a machine would be checking it. At 6k counter waste toner should weigh very little not a brick.
                    • rolls.bo
                      • Sep 2014
                      • 42
                      #25
                      you're right I think like you.
                      in the c3350i series, with early firmware there was this problem of high toner waste, but here I believe there is an electronic or sensor problem not working properly.
                        • 23008
                        #26
                        I've seen this sort of thing on other brands when the MFP is placed near an exterior door. Each time the door opens the temperature drops (winter temperatures), machine stabilizes.
                        • CP-1015
                          • Nov 2020
                          • 318
                          #27
                          Do you have much C2552/4/6/8? Defektiv Developer chip.
