Bizhub C300i - Buying Advice
  • mkonkelz
    replied
    Re: Bizhub C300i - Buying Advice
    Do you plan to use Warranty, in example case of board failure? Because it can be tricky when you're self servicing machine.
    Did they send machine pre-installed to you because then maybe rrohan can be right about passwords they've change.
    Yes, if something breaks i will use the warranty. I spoke to KM before buying. This should be no problem.
    I also can call the dealer at any time, they promised to help me out if something goes wrong.
    It was exactly as you and rrohan mentioned. They did it out of habit.
    I got the machine pre-installed, ready to use.
  • mkonkelz
    replied
    Today i gave them a call and talked to a technician. It was a mistake on their part, the tec who did the install set the passwords to their standard, because normally they don`t sell this machines and they all have service or maintenance contracts. So he set up the passwords out of habbit.
    They instantly gave me the passwords, no arguing was necessary.
    So i am currently doing the installation and setup and the first questions arise:
    Is there a new Firmware available?
    Currently it`s running on Version AA2J0Y0-0100-G00-7B(00)
    Function Version: 1.0
    Can someone (maybe @Bix ) provide me the current version?
    Is there anything special that i need to know about the upgrade process? Things i need to consider or need to know?
    Are there special versions for different installed options or is there always one version including alle options?
    ACS Mode
    I saw that ACS is deactivated by default. Are there any disadvantages in enabling it?
    I would prioritize longevity over print speed.
    System Auto Reset
    Currently i am using the Classic Mode and want to set the default menu to scan or home screen. But when i start the system it always jumps right into the copy mode.
    If i set System Auto reset to 1 minute it will switch to scan after that minute, but won`t start in scan mode if the system is rebooted.
    When i enable the new Basic Mode it will start in scan mode as intended, but not in Classic Mode.
    1-Click Copy / Scan
    Is it possible to configure a 1-Click Copy or Scan?
    I have setup copy and scan programs and made a shortcut on the homescreen. I would like to start the copy / scan immediately when clicking on the shortcut.
    SMB File Naming Issue
    When scanning to SMB the system gives the file an automated name (date + time + etc.) can i make custom names e.g. File Name 08.06.2020 6:00.pdf instead of File Name_3847834784738.pdf?
    And when i assign a file name to a scan program e.g. Scan Programm "Contracts" giving the file the name "Contracts" it will assign it rightly, but if i do the next "Contracts" Scan it will overwrite the old file with the new one.
    I would like to assign a numbering scheme to the file names. E.g. Contract 1, Contract 2, Contract 3, and so on. I tried the "automatic renaming setting" but this will just add the default file name like ContractSkmscan_23450827435.pdf
    General things to consider?
    Are there general things i need to consider or should configure in the settings or service menu?
    What should be enabled or disabled from the default settings?
    Thank you all for helping me out and providing useful information so far.
    You guys are awesome
  • tsbservice
    replied
    Originally posted by mkonkelz
    Today was the day! My brand new C300i was delivered, but my joy did not last very long!
    As it seems my KM dealer changed all the important passwords. CE and also the Admin password
    I told them i would do all the maintenance by myself. The system is bought (no maintenance contract or leasing) and they were / are completely fine with that.
    They are also going to provide me any spare parts from the parts manual if i need some.
    Maybe it was a mistake by the technician who did the initial setup / installation, but now i can`t do any configuration that was planned for this weekend to start with this machine on monday morning.
    Is there a way to reset the passwords or restore the system to factory default?
  • rrrohan
    replied
    maybe when they did runup the tech set all passwords out of habit
  • Bix
    replied
    This is absurd! If you don't have a support contract with them, they must give you all the passwords! They must provide you with at least the EC password (with this you can reset the Admin password).
    During installation the C300i does not require you to change the CE password. So this was voluntary on their part.
  • tsbservice
    replied
    No. Ask them for CE password, then you can change Admin to what you want.
  • mkonkelz
    replied
  • mkonkelz
    replied
    Originally posted by rrrohan
    what part of the LK102v2 do you want to use.
    OCR? Because I always suggest software OCR instead.
    Yes, for OCR and Scan to DOCX and XLSX. I have a software solution, but it would be also great if the System would support that natively.
    I know, that the process would be slower than my software solution, but for small scan jobs it would be handy to have.
    I won`t order it right now. Maybe later as an upgrade if needed.
  • rrrohan
    replied
  • tsbservice
    replied
    i already got them
    Good job. As you are in Germany it may be easy to contact this fine Gentlemen in case of trouble:
  • mkonkelz
    replied
    If you plan to service your future machine wise move would be to find Service manual and Parts List.
    i already got them
  • tsbservice
    replied
  • mkonkelz
    replied
    Originally posted by Bix
    But it is better to always carry out maintenance to avoid finding yourself in failure.
  • Bix
    replied
    Unless I missed something, iSeries also have NO STOP by default. So it will continue to work forever. But it is better to always carry out maintenance to avoid finding yourself in failure.
  • victor_jffrds
    replied
    It is always recommended to replace as needed but the turn off can be disabled during setup.
