Konica Software Switch settings (complete)
    replied
    Re: Konica Software Switch settings (complete)
    Are sure that Engine FW DipSW has HEX value? Back to the learning board then. They are all On or Off.
    P.S.
    Nevertheless you may nail it, just highlight it and reboot the machine.
    Good point, may this is an engine switch not software SW.
  • tsbservice
    replied
    Thank you for this info I will check this setting next time i'm on site.
    I also found out SW83 disables the media sensor but the service manual doesn't state what the HEX setting should be.
    [ATTACH]55423[/ATTACH]
    P.S.
    replied
    Originally posted by jotunn
    You can disable paper type sensing:
    PSWC > Administrator > System Settings > Auto paper detection setting (or "Paper type auto detection settings.") > ON/OFF
    * This setting is displayed when the device is equipped with the option [IM-102: Intelligent media sensor].
    But also you can try to make weight calculation again:
    ■ Weight calculation default settings
    (1) Display the Service Mode screen.
    (For details of how to display the Service Mode
    screen, see the service manual.)
    (6) Touch the Start key.
    Disable Media Sensor SW83.pdf
  • jotunn
    replied
    replied
    Is there a SW to disable the media detect sensor on the C650i ?
    I have a device with 80gsm loaded but it keeps switching the trays to 120gsm.
  • screwdriverassy
    replied
    On color DinA4 machines, old bizhub C3350 (not "i" suffix), changing between "KM" or "Generic":
    Software Swith Setting No. 13
    hex 08 Generic.
    hex 04 Konica Minolta.
    bizhub C3350 software switch for "Generic" <-> "KM"?
  • tsbservice
    replied
    DipSW No.243(bit 0)
    The function to add the name of the login user to the head of the Scan file name when scanning.
    0x00:disable(default)
    0x01:enable
  • rrrohan
    replied
    Originally posted by elmaligno
    That item does not work
    only i series and has to be latest Firmware. its a new switch
  • elmaligno
    replied
    Originally posted by rrrohan
    Disable users from changing trays paper type
    software switch 245 to 02
  • strider5555
    replied
    Here is another one to add. Software SW 24 Hex 01, prevents machine from printing a blank page on custom PCL print job because of a form feed command. Works on everything from C220\C452 series up to I series.
    Blank Page in Custom PCL print data stream.pdf
  • rrrohan
    replied
    Originally posted by tmmdmmm
    You waited until after I left the industry to post this one?!?!?!?!
    when you quit the beacons were lit and i knew it was time to announce it
  • tmmdmmm
    replied
  • Reed
    replied
    Originally posted by progoffice
    Switch 10 Hex 2 will make a Generic (Muratec) a Konica. This is important when it comes to drivers picking up all device options, paper tray information and accepting authentication account track information if current "Generic" drivers aren't available. We sell both, but sometimes Muratec doesn't release drivers fast enough for equipment they offer. We just installed a Muratec C5595i and had to do this so we could use the Konica C550i drivers. Muratec hadn't released them yet.
    If you do this be aware that the IP address may change. I have done this several times on a machine that has been installed and each time the IP address changed to DHCP. I had to go into the network and manually enter the correct IP address
    replied
    Thanks, this is another good one to add to the list I needed it just last week.
  • rrrohan
    replied
