Firmware Bizhub C3110
  • picquep
    Hi, I'm having issues while trying to print from a computer on the Konica Minolta Bizhub C3110, with some computers it will work fine and some don't, all usic the same driver, i guess it is an issue due to the firmware that is old... I have not been able to find the actual firmware to update the machine so I'm looking for it over here.. Does someone have it to share ? email : paul-nonna@hotmail.com
    Thanks in advance, i hope you were able to understand me because english is not my native language...
    • 8144
    Re: Firmware Bizhub C3110
    email sent.
    Firmware Update - Printer & Copier Firmware
    • Me_vs_C3110
      • Apr 2021
      • 12
      Hello all,
      I am in search of a place to get hard line tech info on my enemy the KM C3110
      The Battle currently being fought
      Dose Firmware address the need for SMB v2 or SMB v3? My end game is to move my scan share folder to my TrueNAS server.
      Thus far all I get back is TX Failed Send which points to a SMB Type Mismatch...in testing on Win 10 pro I turn on SMB v1 and Win Updates turns it back off ..repeat..
      She eats Full 6K toner boxes in very short order as well will make a new post for that ...Looking for best thread to add that to?
      My Enemy Collected Intel
      Controller F/W A6DT30G0C02-999
      Engine F/W A6DT0Y00050G001200
      Boot F/W A6DT99G0100-999
      Panel F/W A6DT20G0100-999
      Fax F/W Uninstalled
      Scanner F/W A6DT23G0402-999
      Action Plan:
      Find Intel about firmware <<< This Post
      Collect The Fixed F/W and Tools Needed to installing <<<Step Two
      Build Post about putting her on a diet <<<Coming Soon
      If above gets done get her some memory and maybe a HDD
      Thanks in advance for any input that helps complete the mission,
      WillieCee aka Me
      • Synthohol
        Certified Konica Expert
        • Mar 2016
        • 5824
        SMB version 2.0 is now supported with the following firmware release.
        • Install Controller firmware A6DT30G0C02-9AV or newer
        After installing firmware the following functionality will be available.
        Software switch 219 Bit2 can be set to the following
        • 0 = SMB1.0/2.0 Default
        • 1 = SMB2.0 only
          • 8144
          Originally posted by Me_vs_C3110
          Hello all,
          Fax F/W Uninstalled
          Action Plan:
          WillieCee aka Me
          Happy to help with this special firmware.
          We can supply most major manufacturers printer & photocopier firmware. Click Here To Download - Ricoh, Konica Minolta, Kyocera, Lexmark or Canon Firmware.
          • Synthohol
            • Mar 2016
            • 5824
            i sent him a PM as well
            • Me_vs_C3110
              • Apr 2021
              • 12
              After just a light learning curve on my part to get the file in the printer and reboot her up and just like that everything start working as expected.
              For that I thank you Synthohol
              For the life of me it seems like KM could make that intel little easier for Technically minded User to find and shame on Goo&Tube for showing me everything but 3 lines of text.
              I have a Pdf that would complement those two firmware file if you would like it for your archive.
              EOD:
              KMC3110 Scan share now lives on TrueNAS-12.0-U3
              Thank You again ,....
              • MasterT
                • May 2019
                • 11
                I need latest firmware for Konica Minolta C3110.
                What I have now is this:
                ROM Version
                Controller ROM Version A6DT30G0803-999
                Engine ROM Version A6DT0Y00050G001200
                Boot ROM Version A6DT99G0100-999
                Panel ROM Version A6DT20G0100-999
                Scanner ROM Version A6DT23G0402-999
                Fax Board ROM Version -
                If anyone can help please let me know.
                I wrote to
                copier tech in forum private and email but no answer.
                  • 8144
                  ROM Version
                  I wrote to
                  Message received & firmware sent, thanks for your support.
                  • keszel
                    • Apr 2019
                    • 5
                    Hello.
                    Please send me the latest bizhub C3110 firmware. My email keszel1974@gmail.com or PM .Thank you
                      • 8144
                      Originally posted by keszel
                      Hello.
                      Happy to help. Please drop us an email at either link below.
                      • Dereckachy
                        • Jun 2023
                        • 1
                        frederickagubuzu@gmail.com
                          • 8144
                          • dimoo0
                            • Mar 2023
                            • 6
                            Hi Please I need latest firmware for Konica Minolta Bizhub c3110. My email
                            elshenawyy@yahoo.com
                              • 8144
