Re: C-3110, "initializing"..
Happy to help. Feel free to contact us at either website below.
Pls somebody help me, I need the Restoration tool too. I can't use my printer as it's stuck at initializing. Lewalexzy@gmail.comLeave a comment:
SSD will fix this, remove small panel in back cover and ssd is there easy 5 mins to change.Leave a comment:
Does the engine run during this?Leave a comment:
Ok, so went out the machine yesterday. In between it saying "initializing", it also had all three Color Drums at end of life.. because I've seen these machines do weird things when the drums are at end of life, I sent the customer 3 drums for them to install. They did that, but machine still says initializing. So, I guess I'm going back out with an SSD chip ASAP, right?
OCLeave a comment:
[QUOTE=Oystercopy;1679434]You might find simply power cycling the machine will clear the error.
If not I use the restoration tool this does the trick.
Thank you for that Copy Tech. I searched everywhere, in regular firmware and special firmware and did not find that Citrine file that's referenced in the bulletin you attached.
However, I'm going out there today with an SSD board, hoping to fix the issue.
Thanks!
OC
If not drop us an email if you need the restoration tool firmware.Leave a comment:
[QUOTE=copier tech;1679399]You might find simply power cycling the machine will clear the error.
Thanks!
OCLeave a comment:
Bizhub C3100P_C3110_Procedure_of_Restoration_Tool.pdfLeave a comment:
