bizhub C287 - Medical Images
  • dscmanga
    • Mar 2021
    • 9
    Re: bizhub C287 - Medical Images
    Originally posted by emujo2
    Equipment calibration will do you no good, there is a color gamut that you cannot get outside of..have you ran the color mgmnt tool within the driver? This is where you can assign monitor ICC profiles and more closely match what you see on your screen to what the driver can output, but if you are trying to get monitor bright white to look like printer white the best you can get is the brightness of the paper, unless you have a system that can lay down white ink. E
    Hi emujo2, I'm just looking for software that can do this calibration. I found only Color Centro but it doesn't recognize my equipment, it is only for PRO machines.
    Where do I get this mgmnt tool? Would it be a management tool?
    Where can I find it?
    : D
    • dscmanga
      • Mar 2021
      • 9
      What you see on the screen is RGB, 20 million colors possible; a printer is CMYK, only slightly over 2 million colors possible. In other words, you can get close but not always the same.
      You have a few more options with PS driver than PCL (see screenshots below). From what I can see, its not so much a pure black issue as a color rendering one. A yellow usually does turn greenish when the gamuts don't jive. I would also be curious to know the file type and the software its coming from....
      [ATTACH=CONFIG]48677[/ATTACH] [ATTACH=CONFIG]48678[/ATTACH] [ATTACH=CONFIG]48679[/ATTACH]
      mojorolla is basically what you said.
      With the MDI exams, we leave it as close to the screen as possible, the biggest difficulty is that the black needs to be 100% filled to make the exam stand out. And when it is an ultrasound, for example, the exam needs to be in white and it turns bluish when it is in composite black, while in pure black the black in the background is grayish.
      So I need to find the middle ground between the black background and the tone of the exam. This is the difficulty.
      On the OKI C911 I can do without problems adjusting the color curves, lighter, darker, more blue and so on. But at konica I didn't find any software to make this adjustment.
      • emujo2
        • Mar 2017
        • 1579
        : D
        This is part of the print driver..Properties/color management..You also need to to the machine calibrations with the brightest white paper you can find. have you tried using the dropdown for Web images in color quality? I just noticed this option has been removed in the I series, might still be available in the C287. E
        • mojorolla
          The Wolf
          • 2616
          #19
          Take the red pill and see how far down the rabbit hole goes:
          • Walterj
            KONICA MINOLTA
            • Jun 2017
            • 89
            #20
            Good afternoon. I have already performed all the equipment calibrations.
            I believe that a fine adjustment is missing, I have also tried the adjustment by the PLC driver but it does not correct the problem with the hue.
            Is there any software that does color curve adjustment other than Color Centro? The color centro does not fit this equipment.
            [ATTACH]48674[/ATTACH]
            It would be advisable to use the PCL driver and adjust brightness, contrast and saturation, all this is within the quality adjustment option.
            If you want to use the PS controller you have to activate the PS designer option first.
            Now if I am not mistaken, there are other programs that are precisely to print these x-rays on this type of paper.
            You would have to search, if I find something I will send it to you.
            • GeraldCruz
              • Sep 2023
              • 4
              #21
              Medical images play a pivotal role in modern healthcare. They provide invaluable insights into the human body's inner workings, aiding in diagnosis, treatment, and monitoring of various medical conditions. These images encompass a wide spectrum, from X-rays and MRIs to ultrasounds and CT scans, each offering a unique perspective on different anatomical structures and pathologies. One crucial aspect of medical imaging is the use of surgical mask images. These images showcase the importance of infection control in healthcare settings. Surgical masks, worn by medical professionals during procedures, protect both patients and healthcare workers from potential infections. By examining surgical mask images, medical experts can evaluate mask placement, fit, and hygiene compliance, ensuring optimal protection. In the age of digitalization, medical images are not only enhancing diagnosis accuracy but also enabling telemedicine, remote consultations, and data-driven research. They are a cornerstone of modern medicine, enabling healthcare professionals to provide more precise and effective care.
              • emujo2
                • Mar 2017
                • 1579
                #22
                You're a little late to the party..Do you have a resolution to the issue (over 2 1/2 years old) or are you selling something??
                • Synthohol
                  Certified Konica Expert
                  • Mar 2016
                  • 5827
                  #23
                  dude, thats not a real person, thats skynet.
                  • tsbservice
                    Field tech
                    • 8018
                    #24
                    We have here one real person @skynet ... but agree with U, I never reply with quote on such posts that just makes them a bit legitimate whereas they are NOT.
                    • Synthohol
                      • Mar 2016
                      • 5827
                      #25
                      yeah, haha. the last time i made the reference skynet popped in the thread and had a chuckle i imagine.
                      • Synthohol
                        • Mar 2016
                        • 5827
                        #26
                        heres a nickel kid, go see a movie.
