BizHub C284e strange issue
  • copyman
    Owner / Technician
    • Sep 2005
    • 4700
    Customer said day before they sent a print job and it didn't print so they printed it again and it printed fine. Next day it printed the job that never printed. Is this even possible for the copier to do this? Seems more logical to me print job was on a PC in their office and someone printed it or job was on the network somewhere?
    Never heard of this before so told customer I would look into it and get back to them.
    Any ideas appreciated.
    Thanks in advance
  • patrickjlc
    • Feb 2015
    • 225
    Re: BizHub C284e strange issue
    It could keep it on the HD or memory, or on the pc printer spool job. Sometimes you get a paper jam and printer will keep trying to print.
    Sent from my motorola one 5G UW using Tapatalk
    • rrrohan
      • Sep 2011
      • 1977
      Or it did print and another user accidentally grabbed it, the realised the next day and just place it back on the copier.
      Check job log
      Sent from my Pixel 4 XL using Tapatalk
      • copier tech
        • 8144
        Thanks in advance
        Check the copier is installed on an IP port not WSD.
          • 23008
          Yes, WSD port will do this. I've found 3 year old jobs in the print queue.
          Another possibility is that somebody has a duplicate IP address on a mobile device. When they take the laptop home, the job(s) come through. I've seen this on a couple of occasions. The funny part is that the local IT always asserts that couldn't possibly be the case. =^..^=
            • 16391
            That's a scenario that I haven't thought of. I'll have to add that to my notes.
            • allan
              RTFM!!
              • 5462
              Check job log
              OP to ask costumer to ask around if someone indeed took it by mistake.
              Whatever
                • 23008
                On one occasion I had the IT professional remoted into on my laptop. He watches while I ping the copier's IP. He says: "So? Sure it will ping." I say: "It would ... if the network cable was plugged into the copier ... but it's not. So what am I pinging?" It turned out to be a Samsung cellphone that I could identify by the MAC address.
                On another occasion the IT professional issues me a new IP address for a new install. I say: "There's a problem ... this IP address is already being used, I'm getting a ping without the cable connected. Can I have a different address?" He says: "No, that can't be. I issue the addresses here."
                ??? "Ok, that can't be. Now can I have a different address?"
                • rrrohan
                  • Sep 2011
                  • 1977
                  Printer warns if it detects IP conflict though
                  • allan
                    RTFM!!
                    • 5462
                    Yes some times on the bottom of the screen but not always. Had exactly the scenario BC is describing with the cellphones before. Also identified it to be a phone using the MAC address.
                    Whatever
                    • rrrohan
                      • Sep 2011
                      • 1977
                      Yeah you might be right or it might only check once at startup. I think that's what it's doing when it says Waiting ARP request
