c3926
  • romario
    • Jun 2020
    • 192
    [Error Code] c3926
    Can someone help me with this error, the machine does not allow me to erase the error, the stay button keeps flashing and I change the fuser unit
    error c3926
    [COLOR=rgba(0, 0, 0, 0.54)]
    [/COLOR]
    [/COLOR]
    thanks
    • 23008
    Re: c3926
    What model did you say that was? =^..^=
      • 14754
      Re: c3926
      error c3926
      [/COLOR]
      [/COLOR]
      You need to follow the "A" rank error clearing method in the service manual.
      • avecosat
        • Jun 2012
        • 305
        Re: c3926
        Service mode -System 1 - Initialization -System error clear .Power off - on
        • rrrohan
          • Sep 2011
          • 1977
          Re: c3926
          ive worked on KM for 10 years and ive never done that? strange
          • tsbservice
            Field tech
            • 8019
            Re: c3926
            Search manual for CONTENTS TO BE CLEARED BY RESET FUNCTION.
            System error clear supplement to trouble reset - Erratic operation/display clear and Jam display clear.
            It's basically power user trouble reset
            • avecosat
              • Jun 2012
              • 305
              • romario
                • Jun 2020
                • 192
                Re: c3926
                Thanks the panel was short I wouldn't let me make any modifications or delete the errors change the panel and I solved the problem
                thanks
