Konica Minolta bizhub C224 jam code 3205 only from tray 2
Blessed are they who can laugh at themselves, for they shall never cease to be amused.👍 1 -
Firstly the size in Tray 2 was A3 , and was same problem, after this I change it to A4 like Tray 1 - the problem is the same. Now the settings in both Trays are same - A4. Jamming only from Tray 2 and pick up rollers doesn't stop to rotate. From Tray 1 and Bypass there is no problem.
👍 2Comment
To answer your question, he's already replaced the clutches and sensors for tray 2. First I would replace all three tires and clean the one-ways in tray 2 and make sure the double feed prevent assembly is working properly, replace PS19, reseat the connectors on the PRCB, reflash firmware and if none of that resolved replace the PRCB. It's stream feeding, so either the DFPR is shot, which he already replaced, the feed clutch is shot, which he already replaced, or the clutch is just not receiving its signal to turn off, PS19 not working or the PRCB.
😀 1Comment
