C458 w/ PC-415 dogear
  • FuserNoob
    Service Mgr, CISSP
    • Jul 2022
    • 149
    Greetings Programs...
    I have a C458 with a PC415 supertray that is dogear-ing the leading edge on the rear side of the machine and I cant figure out the cause.
    I'm hoping some of you Froods out there can offer a suggestion
    Thanks!
  • Synthohol
    Certified Konica Expert
    • Mar 2016
    • 5824
    ive seen plenty of hairline splits on the mylar at the edge of the tray cause that.
    have you stopped it every few inches each time to see when it happens?
    if no mylar maybe a small paper fragment in the feed section itself?
    • FuserNoob
      Service Mgr, CISSP
      • Jul 2022
      • 149
      Thanks Synthohol, I'll take a look and let you know
      • FuserNoob
        Service Mgr, CISSP
        • Jul 2022
        • 149
        There was a burr on the back edge of the Mylar where it meets the top of the drawer. One pass with a nail file and 100 sheets paper passage test seems to have done the trick.
        Thanks again!
        • copyman
          Owner / Technician
          • Sep 2005
          • 4701
          Glad to hear it's fixed but keep in mind to also check the rear cable, they pop off if the damper is bad and lift tray bangs down when you open drawer. When this happens the paper lifts but rear side is slightly lower and will dog ear corner of paper
          • FuserNoob
            Service Mgr, CISSP
            • Jul 2022
            • 149
            Thanks Copyman! That was the first thing I looked at. It was only after I asked this question that I found this thread:
            https://www.copytechnet.com/forum/te...aight?t=172777
