the olden days
Anyone remember the Sharp that talked (maybe the SF781?). Had like 7 weird robotic voice prompts (remove original, paper empty, etc). Every office that had that model turned off the voice. It would scare the hell out of a secretary if in the office alone.😀 2Comment
September 78 i started, in fact the 18th....it's my one and only job, it was mechanical NCR and Gold cash tills, and Olivetti & Olympia adding machines, they were great fun, if they played up, quite often it was just a case of bending something, I didn't start copiers properly until about 1981, then it was Sharp, though I did work on a few 3m Scotch copiers, with the pink sheets, it took a couple of minutes to do one copyTip for the day; Treat every problem as your dog would.....If you cant eat it or f*ck it....then p*ss on it & walk away...👍 2Comment
Mita did that in the 1980's. I think it was the Mita 133vox that would voice prompt you to remove jams, add toner, etc. You're right though. It was a creepy robotic voice, and almost every customer that had one, had me snip the speaker wire. If you weren't expecting it, it was jarring. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=👍 2Comment
September 78 i started, in fact the 18th....it's my one and only job, it was mechanical NCR and Gold cash tills, and Olivetti & Olympia adding machines, they were great fun, if they played up, quite often it was just a case of bending something, I didn't start copiers properly until about 1981, then it was Sharp, though I did work on a few 3m Scotch copiers, with the pink sheets, it took a couple of minutes to do one copy👍 2Comment
the stapler jig was the best tool ever. i stole it from konica (or should i say minolta) school before it was able to be ordered.👍 1Comment
My first copier school. Savin 1982. School was in Boston, MAAttached FilesComment
Attached FilesField technician since 1994👍 1Comment
who still has the little orange screwdriver to adjust the atdc pots on the old dinosaurs?
or my favorite from the olden days, the ants marching to the picnic on the warm up screen.
then with a FW update it was gone only later a rocket ship take off was supposed to keep us amused as it warmed up.
bring back the ants! there was another one from long ago and seems those brain cells are gone and i cant5 remember.
maybe other animals a circus?
im sure someone here will either confirm my insanity or remember as well and i wont have to wear the self hugging canvas jacket.
If you changed the language on the EP3050/EP4050 to Dutch the Home Screen displayed ‘U Kunt Kopieren’ which as young lads thought was highly amusing.
I still have 2 x sealed Orange Minolta dust cloths, an EP350z dev bottle that’s now filled with screws and the white collar that came on the drum shaft of the EP450/Z when they were unboxed. The blue user choice card that went on the EP2050 control panel when they flipped over a panel, An EP3170/EP4210 interlock jig on an old set of keys somewhere plus a Minolta keyring that was given out at the end of a training course. I remember on one course they gave us a belt, a mug & some coloured pens.
I’ve worked on Minolta/Konica Minolta since the 310, 300/300RE, EP520/530/530R days with silicone oil & customers pouring toner into toner hoppers. It’s fair to say they’ve made some terrible machines & my memory’s of the 80’s especially are changing interlock switches & soldering dry joints. More mods than you can shake a stick at & visiting some machines on a weekly basis to clean the optics. It’s fair to say reliability has gone through the roof. I’ve been to some machines that haven’t had a call in over 2 years. The worse machines for me were the 350Z, 570Z, 4230, 5400, Di250/350, C352 with finisher
Best machine Di620 & C284 series.. I’ve only seen 2 BW Konicas in the last 20 years & they were the crap Bizhub 215s
This gallery has 2 photos.👍 3Comment
