Konica Minolta bizhub C658
  • zunamiwave
    • Nov 2023
    • 21
    Code: C3101 displayed on a Konica Minolta bizhub C658. Have checked fuser unit and it appears to be in good shape. Planning on checking PS38 sensor next. Any other suggestions greatly appreciated.
  • copyman
    Owner / Technician
    • Sep 2005
    • 4700
    Will code reset if you use the proper "trouble reset" procedure?
    • zunamiwave
      • Nov 2023
      • 21
      thank you for your suggestion. Have tried to trouble reset few times but does not clear.
      • Synthohol
        Certified Konica Expert
        • 5824
        do you know if the fuser is turning and initializing?
        check M11 fuser pressure motor.
        try load check for the motor. 45-6 and 45-7
        boot into service mode with the side door open and get to load check before closing the door then try
        45 1
        2
        3
        4
        5
        6
        7
        M3 M11 Fusing motor high speed Fusing motor middle speed Fusing motor low speed Fusing motor minimum speed Fusing motor standby speed Fusing pressure motor drive
        (pressure)
        (release)
        Drives the motor at the specified speed. Starts the pressure/release operation of the
        pressure roller.
        NOTE
        Be sure to perform the release operation
        whenever the pressure/release operation
        has been performed. *4
