Hello dear fellow techs .
I've been having some problems with 2 bizhub pro 951 machines.
Both are ruining brand new charge units in less than 30k prints. charge grid starts bending and its getting too close to drum unit making developing unit spill toner and also ruining the drum as well.
First i changed only the grid when i first saw the problem starting to occur . Sometimes its starting to bend and rust after 5 to 10k pages. Soon after, the developing unit and drum unit are unusable.
I also did try - brand new drum unit, charge unit, developing unit, cleaning unit and after 30k pages its already dumping toner, charge unit grid its starting to bend and machine is again unusable.
Also moved the printer to check if humidity could have something to do with this, also used couple dehumidifiers and moved the machine over a special carpet and still no change.
I'm starting to think if HV board could have anything to do with it.
I would really appreciate any advice. I'm out of ideas.
Blessings to you all!
