Bizhub C3320i
  • Yazaankhan701
    • Nov 2024
    • 16
    Bizhub C3320i
    Machine have firmware problem. i tried the firmware which my senior (i have learned from) sent me but that not worked. I change the every part and try but still same. Machine turn on but didn't do copy nor scan. Now my senior sent me another firmware which is stuck on MFP CONTROLLLER 40%. I KNOW I HAVE TO DO THE FIRMWARE. But i couldn't found the exact firmware. My senior is in Germany so i am alone to do this work. We are renting machines in the area and on Wednesday i have to give it to back to the customer. If i can have a latest firmware i really appreciate any help. Thank.I am in the field from sep 2019 in cyprus.
  • WisamM
    • Feb 2023
    • 23
    Do you have access to Konika Minolta Infohub (KIKU) on not ???
    If you have, I can help and show you how to download the latest F.W.
    • Yazaankhan701
      • Nov 2024
      • 16
      Unfortunately no 🥺
      • copyman
        Owner / Technician
        • Sep 2005
        • 4701
        Here is latest firmware FW AAJT0Y0-F231-G00-RB. PM me with email address if trouble downloading
        Are you sure it's the firmware and not the USB flash drive? Kon/Min equip is very picky with type of USB drives.
        • copyrooks
          • Oct 2013
          • 209
          This might be going way overboard but I've had cases where I had to use tar reset tool, use partition procedure in order for copier to accept firmware. Use as last resort of course but in my cases, memory and cpu boards were replaced and nothing was working. We lost meter but least of our worries.
          • Yazaankhan701
            • Nov 2024
            • 16
            #copyman thanks a lot freind 🙏🙏😀 you save me. Thank you very much.🙏🙏
