What brand USB-Stick (2-4GB) to use for updating KonicaMinolta machines?
  • Hansoon
    • Sep 2007
    • 3385
    I have many USB-Sticks, most of them are not working to update the KonicaMinolta MFP's
    What brand/type USB-Stick (2-4GB) knowing to be good, are you guys to using for updating firmware for the KonicaMinolta machines?
    Hans
  • Synthohol
    Certified Konica Expert
    • 5824
    heres what i got.
    Approved USB Drives.PDF
      • 23008
      I have generally had success using the smallest USB that will hold the firmware. Another thing: If your machine was made 15 years ago, I probably will not communicate well with a USB3 drive. I use mostly USB2 drives. They may be a little slower, but usually communicate.
      • Max
        • Oct 2011
        • 557
        I use 16 gb Samsung 3.0. Never had a problem with branded names. Tried several cheap unbranded from ebay, never worked, not even once.
        • Duplicator
          • May 2022
          • 245
          Hans
          I use a 64Gb Samsung. It is also important to find flash memory that isn't fake. You can test it with F3 (https://fight-flash-fraud.readthedocs.io/en/latest/).
          I've used sizes up to 128Gb (even on 223). The trick is turning off LBA on the FAT32 partition. The Windows format utility will turn it on automatically for drives larger than 4Gb. For whatever reason the boot firmware will sometimes not recognize the firmware on the flash drive if LBA is on.
          Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
          If I helped you out, please give me a thumbs up! It helps my reputation.
          • copyrooks
            • Oct 2013
            • 209
            Lexar 2.0 4gb 8 gb 16gb
            Sandisk 2.0 4gb 8gb 16gb
            • mitchl
              • Apr 2007
              • 501
              With the i series KM recommends the Transcend USB. I use a 16 gb and have other smaller Transcend sticks. Maybe its because the i series had issues with updates and these seem to work without jumping through flaming hoops. Regardless use HP's format program and yes it does make a difference, depending on the USB its the difference between updating the machine or you pulling your hair out.
              • jotunn
                • 617
                Samsung BAR 32GB
                Works well with C224 and above, including C3350/BH4050. However I can't recall if I tested them with C220/BH223 series.
                • occus
                  • 337
                  Never had any problems with sticks since i use hp_usb_disk_storage_format_tool-2.2.3
                  First put in USB Stick
                  Run CMD
                  Type diskpart
                  Type List disk then press enter
                  Determine which disk is the USB stick (Be really careful here!) Type Select disk * (select disk 1 / 2 / 3 ...)
                  Type clean then press enter
                  Type convert GPT then press enter
                  Type convert MBR then press enter
                  Use HP Tool to format the stick.
                  I use 2/4/16/32/64GB sticks
                  • Synthohol
                    • 5824
                    microcenter black 4g drives worked on EVERYTHING.
                    • femaster
                      • May 2011
                      • 1504
                      Originally posted by jotunn
                      Samsung BAR 32GB
                      I can confirm that we have been successful using the 64GB version of this drive as well.
                      • jotunn
                        • 617
                        Yes, they should work - 32GB versions are getting harder and harder to find - but...
                        Most older machines supported USB memory up to 32GB - so you have to trick the machine into thinking you are using smaller memory.
                        So remove any existing partitions from the brand new memory, then create a primary partition smaller than 32GB, and for any unused space, create an extended partition, and then a logical partition within your extended partition. You can then use the extra space for documentation, rarely used firmware or other files.
                        I've used a 256GB NVMe disk in an Orico USB enclosure split in a similar way as a USB memory replacement for firmware upgrades, and it's worked without problems in most cases.
                        • mascan42
                          • Oct 2008
                          • 484
                          I've never had any luck using anything larger than 16GB on the i-series, even after running the HP format tool.
                          • Cantechman
                            • Nov 2008
                            • 228
                            Run CMD
                            Type diskpart
                            I've saved buying new usb drives many times using those directions.
                            • copyman
                              Owner / Technician
                              • Sep 2005
                              • 4700
                              See attached.
