bizhub c754e hole puncher disabled in print
    replied
    You need to configure the print driver to show that It has a punch unit, and what type. If the driver you are using does not have a way to configure, then you aren't using a Konica Minolta driver.
    Lol. Synth responded at the same second that I did!
  • Synthohol
    replied
    A: incorrect driver
    B: incorrect config in setup tab
    should look similar to this, the port should be set by IPv4 raw port 9100, never trust WSD!!!
    try the obtain device tabs.
  • Enzo
    started a topic bizhub c754e hole puncher disabled in print
    Hello friends. I have a bizhub c754e and I have a problem with the hole puncher.
    it is FS-534. from photocopy the puncher works. from the print it does not work. it is actually disabled in the options selection. what could be the problem? thank you very much
