Konica c224 e can't access service mode
  • JoSer
    replied
    Re: Konica c224 e can't access service mode
    Originally posted by femaster
    The reset code resets the password back to the factory default. Yes, there is a way to set the machine up to not request a password, but it does not completely eliminate it. The password would still be required under certain circumstances like entering from the trouble reset screen.
    Ah! I forgot to check with the default password. The default password is working in CE menu now. Thank you very much!!
  • tulintron
    replied
    Have you tried Clear All Data?
  • femaster
    replied
    Originally posted by JoSer
    Thank you very much! That worked. But unfortunately I switched back from the CE menu and there is still a password set. I thought this code will delete the current password. Is there a way to remove the CE password completely from within the CE menu?
  • jotunn
    replied
    Originally posted by Bruno2001
    I Need your help these are Just the credentials:
    Serial Number:A5YN02700057
    MAC: 00:20:6B:92:38:34
    CE:E6F33-SYW7Z-MEBHR-UDG2U-7C8ZU-GG8YD-EMZRG-AYTTX
    Wrong serial number - too short, should be 13 characters long.
    Ok, I nailed it.
    You missed one "0", so the proper serial number seems to be A5YN027000057
    However your code is expired, I need the fresh one...
    Failed to verify the CE Password Reset Request Code.
    The entered CE Password Reset Request Code cannot be used due to the expiration. (MFP date in the code: 2023/10/19)
  • jotunn
    replied
    I also got a new code now and cannot enter again:
    4HZBW-N65C8-K5WRJ-XZWLZ-JEKJS-CG8YD-EMZRG-AZDL3
    The code removes the currently set password and restores the default one (and as a tech, you should know the default password).
    It is not possible to remove the password completely - you can only disable CE Authentication in Enhanced Security mode, then the machine will not ask for password anymore.
