bizhub c3351
  • Gab
    • Aug 2015
    • 668
    bizhub c3351
    I am planning to import some biz c3351. Are they good machines ?Any problems they have?
  • copyman
    Owner / Technician
    • Sep 2005
    • 4616
    The C3351 is an older model but overall not a bad box. Good for low volume use. There were some improvements from the C3350. The main issues I've had with the machine is customer removes fuser because of jam and break the plastic guide on bottom of fuser. And if they copy a lot the scanner belt breaking.
    • adecanmin
      • Oct 2010
      • 291
      It has built in Wi-Fi. The user as well as the tech interface is Konica Minolta. The c3350 was not and took a bit to get used to. There is a guide that crumbles over time that causes jams on 2 sided prints. To replace it, half the machine has to be disassembled. They get easier the more you do. The first one is rough. The drums won't go 60k before they start putting a line on the edge of the prints. In a low use environment not too bad. Larger volumes I would want an A3 in there.
      • AlaskaCopyTech
        • Jan 2024
        • 77
        I service C3351s and am a big fan of the model just be sure to watch the age as these models are getting rather old and if you're looking into to getting a used and abused one it's probably not worth it.
        • femaster
          • May 2011
          • 1482
          This right here is the main reason I won't recommend a used unit of this style (C3350 or C3351). If the machine has spent the majority of it's life "on" and not in low power or sleep, It will have baked the hell out of the plastic guide above the fuser. That plastic is so brittle that even breathing on it wrong will cause the tiny fins on it to break off. Then like you said, in order to replace that guide you have disassemble half the machine. It's a real Pain in the ... to change out, much harder than it should be.
          Another thing I've found in the C3350 models is that in order to replace that guide, you are removing the entire scanner assembly. When you pull out, or reinsert, the ribbon cables for the scanner on the main board, the traces on the end of the ribbon cables like to peal off resulting in a dead scanner. They may have improved that in the C3351 models, but we have never tried to replace the guide in that model after all the problems with the ribbon cables in the C3350. We stopped fixing the guides in those machines because every time we pulled one apart, we had to replace the ribbon cable for the scanner as well. After a couple repairs, we decided to just declared the machine dead once the plastic guide started to disintegrate.
          • tsbservice
            Field tech
            • 7972
            Ouch...bookmarked this post to remember me when the time comes.
            • Gab
              • Aug 2015
              • 668
              So is there any reliable A4 color konica minolta (or Ricoh or other model) machines (for used machines)?
