IC-609 network problem
  • Gerg?
    • Jul 2008
    • 67
    Hi,
    I have a C4080 with IC-609(Hickary Print Controller). Both of them have a network card. The machines are in separated vlan from other PC-s. When I ping them from another vlan the C4080 answer correctly bud the IC-609 doesn't.
    The AccurioPro Print Manager need to use port 30083. In case you ban the port 30083 in the IC-609 you can ping it, you can print from the driver but not via AccurioPro Print Manager.
    Any advice would be greatly appreciated
    Gergő
