MINOLTA BH284e ADF
  • M1963
    • Jun 2017
    • 66
    MINOLTA BH284e ADF
    greetings.
    machine does not see ADF 624
    problem occurred after battery replacement
    SYSTEM 2 SELECTED DF624
    DOES ANYONE HAVE AN IDEA
    thanks
  • Woxner
    • Jul 2011
    • 848
    Go into system 2 and look for df settings. Select df you have
    • tsbservice
      Field tech
      • 8009
      Could be DF isolated?
      • copyman
        Owner / Technician
        • Sep 2005
        • 4685
        Remove rear ADF cover and check connector. I've had a few off lease machines that the ADF cable was pulled when moved which disconnected it from the ADF board.
        Also you can try initializing the machine. Service mode, sys 1
        • M1963
          • Jun 2017
          • 66
          I already did that.
          is there a DIP SW to activate the ADF?
          • M1963
            • Jun 2017
            • 66
            I tried with another ADF.
            the machine was working normally before replacing the battery
            • copyman
              Owner / Technician
              • Sep 2005
              • 4685
              Did you initialize the machine? Service mode, system 1
              Also when ever I've replaced the battery I had to do complete new machine setup, machine type, etc etc
              • M1963
                • Jun 2017
                • 66
                thanks for the support
                I thought about that possibility but I don't have the MACHINE and TYPE data for BH284e, maybe you do?
                • femaster
                  • May 2011
                  • 1504
                  Screenshot from the manual covering all 3 of the slower Color 4e machines.
                  • tsbservice
                    Field tech
                    • 8009
                    That may be your problem wrong machine type!
                    • M1963
                      • Jun 2017
                      • 66
                      unfortunately this table does not suit me, I need it for the black and white machine BW BH284e
                      serial number starts with A61G02-
                      Can I change these parameters without resetting or upgrading the firmware?
                      • tsbservice
                        Field tech
                        • 8009
                        Here you are:
                        Should be 4 and 2 in your case.
                        • femaster
                          • May 2011
                          • 1504
                          Crap, sorry about that. I swear I saw color somewhere in the thread, so my mind was focused on the color models. I see TSBSERVICE got you covered though. Hopefully that gets you back up and running.
                          • M1963
                            • Jun 2017
                            • 66
                            all ok
                            thank you
                            • copyman
                              Owner / Technician
                              • Sep 2005
                              • 4685
                              all ok
                              thank you
                              Well can you at least tell us what solved the issue???
