224e with error c2564 (tcr 0.0%)
  • sanvicente
    • Aug 2011
    • 31
    I am dealing with a bizhub 224e showing c2564 over and over.
    It has 170k. Started to print with lower density. Another tech went and saw the drum with a scratch and low developer so he assume the drum was the cause. He came back day later with dv512k and dr512k, both oem and new, that works for a couple of days an then came the same problem. Then came back with the hoper section and toner but the machine start to show the c2564 code and 0.0% tcr ratio. Manual add toner wont change a bit that tcr ratio.
    Now the machine is in the shop and I have to deal with it.
    allready swap another hoper, the FRB, dv unit and dr unit. All this taken of a working machine.
    changed new chips for Dv and Dr units with out succes. uploaded firmware also with out succes.
    machine starts, do the warming and then came with the code. If I run the reset some times I can even print the counter or the test and then get the code. Besides the light grey color the test and counters looks great.
    With costumer the machine was on oem toner, the second toner was katun (due the lack of oem). This katun is almost full so I dont think is toner problem.
    Searched in the forum and only two treads with this code, but not the same issue. Searched also for 0.0 tcr on the forum but after several read I dont see any tread that could help (maybe because I was all day with the same machine)
    Only step I have not performed as stated on the manual is PRCB. Does any one of you guys has ever come with something like this?
    thanks in advance
  • copyman
    Owner / Technician
    • Sep 2005
    • 4700
    Re: 224e with error c2564 (tcr 0.0%)
    Weird replacing the drum & dev didn't solve the issue. That's all you usually need to do.
    Keep in mind ANY over life consumable can affect ANY other color.
    What are the other drum life counters? Other dev units & level history in state confirm?
    Not sure if your post said you tried swapping HVPS but would look there as well.
    Doubt it's the PRCB. Like when you call hotline they always blame the main board but rarely is bad!
    Good luck and let us know what it was.
    • Woxner
      • Jul 2011
      • 848
      Does it look like its pulled dev. These can pull dev in 20 seconds. Could be bad hv if so. Chk the little holes in the back where dev plugs in. If clogged it can pull dev
      • sanvicente
        • Aug 2011
        • 31
        Yes! Changing dev and drum and uploading firmware usualy do the trick. Its weird specially because the low meter.
        this is a b/w machine so no other counters. I also reset counter for fuser and transfer with the same result.
        Im going to swap HVPS on monday.
        Woxner
        • tsbservice
          Field tech
          • 8016
          Originally posted by sanvicente
          thanks in advance
          For some reason machine is not reading correct TCR level. New dev unit and another FSB leave only bad PRCB I would think.
          • Hansoon
            • Sep 2007
            • 3385
            And with the BH-C-284e/364e series "over life" is defined as what?
            Resetting once developing units and resetting once drum units is already causing over life trouble?
            Not knowing this scares the crap out of me because we have to do that from time to time for cost cutting reasons.
            Hans
            • drowranger
              • Jul 2015
              • 122
              Hi . I would check if toner is transporting to the dev first. There is a common issue with 4 series with white bushing on the hopper gets contaminated and toner does not flow to the dev unit.
              Please reefer to this post for more info and order the part if required.
              C224e/C284e/C364e/C454e/C545e cyan dev unit problems
              Good luck!!
              • CP-1015
                • Nov 2020
                • 318
                Hans
                It is cheaper to swap all drums before installing a used machine than have later trouble. You never know if any unit was swaped from another machine with much more clicks. Drums for 4 series are not expensive. Only drums - without noice - for 8 series are expensiver. I swap only drums, blades and developer - instead of the whole units, except the black developer units.
                • Zesti
                  • Jun 2009
                  • 308
                  Had same kind of iisue on c454e Magenta unit, the TCR was showing 0.0% percent no matter how much toner is added. The problem was bad toner. I had in my stock an older C250 Magenta unit, used its developer to check and all was fine. If your toner feeding system is OK, I'm sure toner is the culprit.
                  • tsbservice
                    Field tech
                    • 8016
                    Interesting I have similar issue. What was magenta CQ in your case? Mine is perfect although M TCR is 0,0%
                    Author, apologize for hijacking your thread.
                    • Woxner
                      • Jul 2011
                      • 848
                      If the cq is good try running the Is initialization and reset then ck the value. I had a 450i so this and i could not get value above 1%. Then after it went to 6.6 kust thought about this again
                      • tsbservice
                        Field tech
                        • 8016
                        Ok thanks. Will try and report back.
                        • REGSIS
                          • May 2016
                          • 435
                          Developing & Imaging units on i series are simply bad.
                          • REGSIS
                            • May 2016
                            • 435
                            thanks in advance
                            You are very likely dealing with a sticky solenoid which prevents developing unit to rotate.
                            You'll have to open PWB box to gain access to it.
                            Remove a sponge from solenoid and glue down a piece of cardboard to create isolation.
                            Sponge falls apart during time.
                            Counter doesn't matter in this case, time does.
                            • Toxic
                              • 697
                              I had recently same problem on C227 and customer use non OEM toner.(black)
                              Fortunatly it was simple diagnostic, no black coverage and grinding noise during print.
                              TCR black 0%
                              After inspection of developing unit i see damaged gear od dv unit because whole unit blocked rotation and can not turn not even by hand.
                              I saw case like this just one time before on C224 long time ago and that customer also use non OEM toner.
                              Lucky for them black developing unit is not expensive.
