Good morning, it's a Konica Bizhub C452. Although it's a somewhat old machine, it only has 43,000 prints. The yellow stains appear only in the yellow color, as if the drum wasn't completely erased. The cleaning blade on that unit has already been replaced. Any ideas? Thanks for your time.
Konica C452 Yellow Stains
No disrespect, I have to ask are you a new technician?
First thing is you should change the "complete" drum unit not just blade. You can rebuild drum units with aftermarket parts but you also install new drum along with cleaning blade. Plus you need to change chip so machine will stabilize and calibrate. Bottom line is you need new yellow drum. -
You should be able to swap the yellow drum unit with the magenta or cyan drum unit to see if the problem follows to the swapped color. If it does, there must still be an issue with the drum unit. FWIW, swapping in a whole new unit will avoid a few more issues than just doing a complete drum unit rebuild as copyman mentioned.
I printed three images and the problem returned. The yellow spots persist. I replaced the drum, cleaning blade, and eraser lamp in the imaging unit. It's as if the yellow drum is still loaded with the yellow part of the image, as if the eraser lamp's power isn't enough to erase it.Comment
It's likely the original IU in there, over 15 years old. I would just replace the entire unit with a new one.Comment
What I did to see where the problem really was, was to remove the drum from the cyan unit, and place it in the yellow image unit, and I put the yellow drum in the cyan unit. I also changed the erase lamps, the ones that come in the lower part where the drum-developer unit goes, and there the problem with the yellow spots continues, it seems that the erase lamp does not "erase" the image from the yellow drum in its entirety.👍 1Comment
Replace Your Drum And Blade , Or If U Don't Want To Replace Your Drum. And Blade ! Increase Image Background Adj =
{Call the Service Mode to the screen} {Imaging Process Adjustment} -> [Image Background Adj}Use the [+] key For Y Color to change the setting valueTo 5 ] - And Go Back To Imaging Process Adjustment And Touch Start Button To complete. You JobComment
The last thing I did was move it and set the value from 7 in service mode - image adjustment process - transfer voltage fine adjust - to 7, and the yellow spots disappeared. I know I need to replace the drums. Even though this machine is old, it doesn't print many copies. The strange thing is that the imaging units are very worn, and almost all of them need developer powder. The TCR value averages 8 - 8.9 for color and 12.5 for black. Therefore, the print quality is lacking.You do not have permission to view this gallery.
This gallery has 1 photos.Comment
Developer in old even not over used units suffers from deterioration and losses its ability to attract toner.A tree is known by its fruit, a man by his deeds. A good deed is never lost, he who sows courtesy, reaps friendship, and he who plants kindness gathers love.
Blessed are they who can laugh at themselves, for they shall never cease to be amused.Comment
