Konica Minolta bizhub 368E jamming on side
  • brent
    • Nov 2008
    • 1208
  • brent
    • Nov 2008
    • 1208
    • brent
      • Nov 2008
      • 1208
      Re: Konica Minolta bizhub 368E jamming on side
      Hopefully I can Insert picture. First time using iPhone to upload pics
      • splblazer91
        • Jul 2014
        • 204
        3205 is always the fuser or fuser drive assy. Do you see brown dust (rust) near the back of the fuser? If so, replace drive assy.
        • brent
          • Nov 2008
          • 1208
          • kingarthur
            • 1306
            did you replace the transfer roller when you replaced the belt. I've had this a few times, and most times when I've replaced the transfer roller, it's stopped doing it...and no...I cant explain it
            • tsbservice
              Field tech
              • 7942
              Hi brent, did you manage to resolve it? I have similar case and waiting on parts to arrive. I will look at PS2 fusing loop actuator/sensor.
              • arahael
                • Mar 2013
                • 97
                Hi. Look at slim foil little above regisration (under transfer belt) because of scratches. Or replace regisration to check. Good Luck
                • brent
                  • Nov 2008
                  • 1208
                  Headed out tomorrow to see if A different fusing section will work along with a different transfer roller since I already replaced the transfer belt
                  • copyman
                    Owner / Technician
                    • Sep 2005
                    • 4576
                    Just curious why machine needed a trans belt with only 50k on it? I know another poster said about replacing the trans roller with belt. Again way low meter to need any of those parts including the fuser. I have 4 & 8 series machines with over 300k and never replaced any of those parts, unless damaged by customer.
                    What happens if you press slightly on the side door while paper coming up the side? If the fuser don't fix it I would look more towards side door being loose, warped. Also look at reg clutch, drive gears, etc. Just don't make sense with that low of a page count....
                    • brent
                      • Nov 2008
                      • 1208
                      I agree. Low meter machine for sure there was damage to the belt for some reason caused by the separator finger on the transfer belt and then on that model there is no screw in that black guide was loose as well unfortunately I never made it to the business today but I’m gonna try to go tomorrow and you are right it does have a super low meter I will look at the door as well since obviously people can hang on that and bend it
                      • brent
                        • Nov 2008
                        • 1208
                        Today I replaced Diffusing section also the transfer roller. And I ran 150 double save a copy is not one problem so hopefully that fixed it LOL thank you everybody for your help
                        • tsbservice
                          Field tech
                          • 7942
                          Hi brent. Good to know you fixed it. I should keep in mind this second transfer roller may be a bit problematic on faster models than on C258 for example.
