c-4512, c-4511 error codes on KM c6000L
  • schlf
    • Feb 2022
    • 18
    [Error Code] c-4512, c-4511 error codes on KM c6000L
    These two error codes appeared after chart setting of the two side printing. Service manual says to check input for the motor and tilt correction home position sensor but I really have no clue what the codes are. I'd really appreciate any help if any of you guys ever has similar problems.
    And the aditional problem is i definitely won't find new writing unit to replace it
    • 23008
    Re: c-4512, c-4511 error codes on KM c6000L
    The two codes: C4511 & C4512, are errors resulting from the yellow laser being unable to complete it's adjustment.
    It's possible that the inside of the yellow laser is dirty, or you may need to replace the yellow laser unit. It's not quite as easy as it sounds. =^..^=
    • schlf
      • Feb 2022
      • 18
      I'll try that but a little bit uncertain about what to clean it with, will rubbing alcohol will get the job done? One more thing, tilt correction home sensor and/or the motor for Y and M write units do they have any input code to check them from service menu. Couldn't find anything in the service guide i have at least
        • 23008
        I would use a microfiber cloth and non-ammonia glass cleaner. Alcohol is OK too.
        You may check "Color Registration Auto Adjustment" for inconsistent values. =^..^=
        • schlf
          • Feb 2022
          • 18
          Color reg auto adj. In fact returning me c-4512/11 errors. Although I'm not really sure what's the value range for it to look at the old data.
          One more thing i'd like to make sure about is how chart adjustment for duplex could possibly cause it.
          • kandod
            • Mar 2010
            • 58
            Originally posted by schlf
            ... how chart adjustment for duplex could possibly cause it.
            When executing Chart Adjustment, Mag. Skew Adjustment is performed automatically (to compensate face-back misregistration due to image skew). When Mag. Skew Adjustment value changes Color Registration Auto Adjustment is performed automatically, and the error pops-up. Perform Both Side Adj. instead.
            • schlf
              • Feb 2022
              • 18
              Both sides adj. giving the same c4512 error.
              • wjurls
                • Feb 2017
                • 498
                Try swapping the yellow laser unit "LPH" with the Cyan and see if the error moves with it.
                I had a C7000 once blow 2 of 4 units due to a possible power surge.
                The machine auto tests yellow first and then moves down the list from there. In my case it was throwing a yellow code c-4511. Replaced yellow just to get a magenta code next c-4512.
                I am currently parting out a C6000 if you end up needing a LPH unit. Just PM me if interested.
                  • 23008
                  Keep in mind that the black laser is unique, not the same as the color lasers. =^..^=
                  • tsbservice
                    Field tech
                    • 8019
                    A bit offtopic but... nowadays it would be interesting sending parts from USA to Russia
                    • schlf
                      • Feb 2022
                      • 18
                      Sending anything to Russia now is quite challenging I suppose.
                      However, are there procedures I need to do right after swapping the write unit like in i/o checkmode, and also if there is any way to check if the sensor is working. because it seems like motors are fine for both units i'm getting error codes.
                      • schlf
                        • Feb 2022
                        • 18
                        Btw about write sensor initial position memory (that's not the same of course but in case that's matter evev a bit)
                        +00078 Y
                        +00021 M
                        +00053 C
                        +00081 K
                        • kandod
                          • Mar 2010
                          • 58
                          All 4 Write units are identical partnum A1DUR70U00.
                          No procedures are needed, just swap the units (and remember original position) and DO NOT write initial position memory. You can also use similar sensor from other parts for diagnostics (I guess).
                          • schlf
                            • Feb 2022
                            • 18
                            Forgive me, but if you by any chance know what the approximate range of skew adj. I've tried to move it manually by simple rotating the motor but however didn't know where that range ends to calculate estimated values and yet blindly rotating the motor itself didn't work
                            • schlf
                              • Feb 2022
                              • 18
                              One more thing, swapped M and Y units and ran the machine in both cases err 4512
