NEC 25C5/C253
  • copy guy
    NEC 25C5/C253
    I'm new to this forum so be nice. My machine gives jam codes 2001 and 3001, jams usually at the reg roller only from tray 1 with Z folds. Bypass and tray 2 feed fine. Acually tray 1 will feed fine with only 1 sheet in the tray. It appears to be string feeding as if it does not see paper at the reg roller and attempts to feed two more times. I've adjusted loop timing from one extreme to the other. I've replaced tray 1 feed head, reg roller assembly with sensor and the print control board. NEC has run out of ideas and they have not heard back from K/M. Any help would be appreciated. Thanks.
    Good luck and may the schwartz be with me.
    If you recognize that line, yes, I'm copy guy from the D-Net forum.
