Konica Minolta C368 - Fiery
  • Kenny
    • Jun 2009
    • 526
    #16
    • emujo2
      • Mar 2017
      • 1579
      #17
      Re: Konica Minolta C368 - Fiery
      I'm having a hard time with this...Your pic shows unconnected SATA HDD connections..You cant put a IDE or SSD drive in its place..If you are that unsure, pull the connections, take them to Best Buy and say please sell me a HDD that will fit this..Someone already posted the size needed. E
      • Synthohol
        Certified Konica Expert
        • 5824
        #18
        Just use a laptop size sata hdd.
        Most scrap copiers will have a free one
        • Kenny
          • Jun 2009
          • 526
          #19
          fiery is now online and working guys thanks for your help,
          ran system software, turned fiery option off/on disabled IPV6 and fully functions,
          • Kenny
            • Jun 2009
            • 526
            #20
            Hi Guys,
            we are having a problem with this fiery disconnecting itself and going offline, when we reboot the copier and Fiery it comes back online,
            Ive checked that the IP address is not duplicated, does anyone one have any ideas what could be causing this to happen.?
            • Kenny
              • Jun 2009
              • 526
              #21
              Originally posted by Kenny
              Hi Guys,
              EDIT: managed to sort this guys by doing the following (other tech posted while i was on holiday)
              Adjusted power save settings, disabled IPV6 settings for both machine and fiery, adjusted network speed to allow 1GBS. Turned off TCP socket settings.
              • Ziggy
                • Feb 2018
                • 732
                #22
                If you haven't already done so disable sleep mode on the copier and turn off weekly timer. Also web into the Fiery and set it to auto update so the Fiery patches will stay up to date.
