Konica C227 image
  • GeorgeBest
    • Jul 2009
    • 526
    Konica C227 image
    HI
    customer refers to an image problem and asked for 3D glasses . .
    Not much experiences in this model, is there an adjustment procedure for correcting this?
    Thanks in advance
  • copyman
    Owner / Technician
    • Sep 2005
    • 4700
    Re: Konica C227 image
    Originally posted by GeorgeBest
    HI
    outlining in color mode not good. (see picture)[ATTACH=CONFIG]54837[/ATTACH][ATTACH=CONFIG]54838[/ATTACH]
    Thanks in advance
    Try cleaning print heads & IDC sensors (near transfer belt) and do gradation adjustment. If this don't work and depending on life counters may need the magenta drum replaced. You can swap color drums around to see if issue follows.
    • tsbservice
      Field tech
      • 8016
      Probably K drum needs replacement. Colour units on this model are IUs no separate drum unit + developer unit.
      • Gift
        • Mar 2011
        • 2459
        Magenta offset - I'd start with cleaning the IDC sensors and laser glasses, too and check the ITB for marks that could confuse the sensors - if everything is ok run gradation adjust from service or admin mode like suggested by copyman. Checking the remaining consumable lifetimes couldn't hurt, too.
        • rrrohan
          • Sep 2011
          • 1977
          Everytime ive had this occur just get customer to restart. And the start up stabilisation almost always fixes it
          Sent from my Pixel 4 XL using Tapatalk
          • femaster
            • May 2011
            • 1504
            Works almost every time. Full reboot and problem goes away.
            Of course, it's not like this happened for no reason, so there very well could be other potentially issues that lead up to that. I'd definitely take a look at the parts others have recommended, but a reboot is good way to clear that up temporarily until you can get the time to take a deeper look at the machine.
