Firmware for bizhub 550i/650i without A800 Memory Board
  • Gift
    • Mar 2011
    • 2459
    #16
    Re: Firmware for bizhub 550i/650i without A800 Memory Board
    Originally posted by occus
    That would interest me too. Unfortunately I can't answer that. Apparently I don't have full rights in Knova. I can't find the RFEU_BT2210861EN.
    But I'm not sure if a missing board will perform the same speed.
    I can't see it, too on KNOVA....
    I checked BSLJ online parts manual for same "changes" and that's some info if you pick the memory board:
    - For Japan (AC74/AC75001), USA (AC74/AC75011) and Europe (AC74/AC75021) destinations, "Memory board", "Mounting Plate",
    "Power source harness" and "Screw (V125030803)" ) 4 pcs" have been discontinued. [Figure 1]
    - Due to the above parts discontinued, "PWB Assembly(PWB-BASE ASSY)" and "PWB Assembly(PWB-CPU ASSY)" have been added
    for Japan (AC74/AC75001), USA (AC74/AC75011) and Europe (AC74/AC75021) destinations.
    - Two bent points of "I/F Flat Cable /W" have been added.
    Due to this, the part number of "I/F Flat Cable /W" has been changed. [Figure 2] [Figure 3]
    [Parts Combination]
    The following parts are not compatible as single part.
    It becomes possible to exchange new part reported with this PMN since the Applied Machine Number in applied Product info.
    - "PWB Assembly(PWB-BASE ASSY)": AC75H02801
    - "PWB Assembly(PWB-CPU ASSY)" : AC74H02Y00 (for bizhub 650i) / AC75H02Y00 (for bizhub 550i)
    In addition, The following parts will continue to be supplied as service part only
    for machines equipped with "Memory board" in the market.
    - "Memory board" : AC74H02A01
    - "Mounting Plate" : ACDF135201
    - "Power source harness": AA2JN15B00
    - "Base Board Assembly" : AC74H02101
    - "CPU Board Assembly" : AC74H02P08 (For bizhub 650i) / AC75H02P08 (For bizhub 550i)
    [About Machine Identification]
    The machines equipped with "Memory board" and machines not equipped with "Memory board" can be distinguished by the applied machine number.
    - The machines equipped with "Memory board"
    : S/No. AC74xxx0yyyyy (The 8th digits of Applied Machine Number is "0", "x": Model No. Last 3 digits, "y": Applied Machine Number)
    : S/No. AC75xxx0yyyyy (The 8th digits of Applied Machine Number is "0", "x": Model No. Last 3 digits, "y": Applied Machine Number)
    - The machines not equipped with "PWB Assembly(A800)"
    : S/No. AC74xxx7yyyyy (The 8th digits of Applied Machine Number is "7", "x": Model No. Last 3 digits, "y": Applied Machine Number)
    : S/No. AC75xxx7yyyyy (The 8th digits of Applied Machine Number is "7", "x": Model No. Last 3 digits, "y": Applied Machine Number)
    The same modification bulletin (KOM220414E0) is attached to the CPU + baseboard so I think they made same changes to these parts for making that memory board obsolete.
