Re: 8 Series Drum Unit - Thick Black Line Bizhub 558
tried with oem and reset the toner bar solve the problem ?
i have seen this happen on new drums.(OEM) it happens when custmer toner runs out customer puts new toner in and bar does not reset so it stays adding toner mode for eons. also generic toner we had to use did this. seen this on I series too. after resseting toner bar and new drum it does not happen again. I tell customer to make sure toner bar resets. If it does not i tell them to turn machine off till i get there. We have SSD tickets open for this on the generic toner we had to use during the shortage. But also when you put new drum in the voltage goes back up to 1800 to 2200 volts under table tab in service mode and life counter resetsLeave a comment:
But can't solve the thick line at charge roller. It won't clean and caused sponge with black line.
Change to new cleaning blade also can last 5-10k yieldLeave a comment:
If this a charge issue I'd assume the entire drum should be covered with toner background and not just half of it showing some banding.Leave a comment:
Possible drum chip effect the drum charge caused this issue?
Used 4 series chip for this experiment.
But 4 and 8 series chip compatible right?Leave a comment:
In my experience this problem occurs in both original and rebuilt units. Some originals fail even with 30k impressions or less. Even the manufacturer has changed the black foam cleaning brush for a spiral brush (they are aware of the problem) with no good result.
And referring to the comments I read about the long life drum, apart from the fact that nobody says they have to have a minimum firmware version from which they can be used, they don't last anywhere near that "extra long life".
That's my experience...and I have hundreds of machines wish models.....Leave a comment:
Hi Guys ,
Any one facing this problem before ? problem occur on Bizhub 558
Changed drum , blade , sponge , charger roller and new chip . ( CET BRAND )
Had changed all the part in drum unit but problem occur again after 10K usage or less .
There is black thick line on charger roller and sponge .
We replace to new part but problem will repeat again .
Use original KM toner .
Anybody got any idea for this issue?
[ATTACH=CONFIG]56181[/ATTACH][ATTACH=CONFIG]56182[/ATTACH]
Try different brand of aftermarket parts. Or like the others suggested just get a black drum which aren't that expensive. A reman aftermarket drum isn't much more than rebuilding yourself.
I rebuild "8" series drums all the time with aftermarket parts and last just as long if not longer then OEM drums. Drums with PCR's are crap! Doesn't matter if OEM or not. Might be ok for lower volume like small printers but not higher volume copiers. I'm sure Kon/Min wanted to sell more drums and didn't like how the "4" series drums lasted way past rated life!Leave a comment:
Check the development unit for any build ups I have had similar issue before, also make sure you chip the drum unit when replacing this is very important with these machine as it resets the charges.Leave a comment:
Perhaps they made a bad batch - I made experiences with faulty blades for ricoh systems - the rubber edge wasn't produced smooth & even enough and if you lied it on a desk it was clearly uneven.
No reason to be clueless if everything is so obvious....Leave a comment:
- high temperatures in the drum area? Check filter and check temperature of ambiental sensor.Leave a comment:
