Re: Bizhub 808 making noise when feeding from bottom cassettes
We had an 808 with around 2.2M pages that started making noise and had jamming issues when feeding from the bottom 2 large capacity trays. It turned out to be the drive motor for the feed units in trays. The spiral gear teeth on the motor shaft had worn down. After replacing the motor noise and jams were gone. I'd take a look at that motor and see if those teeth are worn down. Look close, as it's not always easy to tell.
Craziest thing how plastic gears can wear down metal, but somehow it happens.
The only references that I have to noises on this model are associated with the External Paper Source, and overfilled waste bottles. I don't think either of those are your issue. =^..^=Leave a comment:
These 808's have been mostly solid from my past experience, but I have one on the field that is making a pretty audible noise from the bottom two cassettes when paper is printed from the bottom trays. Sounds almost like the same noise you would get when a waste tank has a bound up auger, more like a loud rattle than a grinding noise. I'm terrible at chasing down noise issues, and the solutions file has nothing. Has anyone experienced anything like this on any of the Minolta style machines(654, 652, 650, etc.)?
A Audio Example would be neat. Its easier to identify the sound source with audioLeave a comment:
