Konica Bizhub Pro 1200 BW
  • daveinli
    • Sep 2009
    • 11
    Hi, hoping someone can help.
    I do not see where this FM34 is located in the parts manual. Every other fan is shown.
    Does someone have a later manual that might show this FM34 fan or know the I/O number to test
    Error Code 5342
    • Description: Collection pipe cooling fan (FM34) power abnormality. The FM34EM error detection signal is detected twice in succession within a specified period of time after FM34 was turned ON. At this time, 24V is normal, but an error detection signal (blowout of ICP) is detected.
    • Causes: Collection pipe cooling fan (FM34) Printer control board (PRCB)
    • Remedy: 1 Check the connector connection and the wiring between PRCB and the fun, and repair it if any abnormality. - 2 Rotate the fan by I/O or hand, and repair/replace it if any abnormality. 1-L 3 Replace FM34 and PRCB at a time.
    Thank you
  • Synthohol
    Certified Konica Expert
    • 5824
    Re: Konica Bizhub Pro 1200 BW
    just use search in the pdf!
    but here ya go anyway
    • daveinli
      • Sep 2009
      • 11
      You would not happen to know where this is. I am hoping it is not behind the toner bottle.
      • Synthohol
        • 5824
        i see that fan sitting directly above one of the wheels on the frame.
        should narrow it down.
        • Shaun
          • Oct 2023
          • 7
          looks like behind the controller board
          • daveinli
            • Sep 2009
            • 11
            Thank you everyone for the responses. Anyone know the I/O number to check fan.
            FYI, I must have had an old version of the parts manual because I found the same image and it said FM12 not FM34
            • wjurls
              • Feb 2017
              • 496
              Parts layout diagram shows it behind the printer control board.
              • daveinli
                • Sep 2009
                • 11
                Thank you, this is exactly where it is.
                Not an easy task for anyone. Control Board is the easy part. Getting the backing plate off is the nightmare.
                • wjurls
                  • Feb 2017
                  • 496
                  Wait until you have to pull the waste toner tubes out. That's a lot of fun too!
