Konica Minolta Bizhub C250i market place
  • Synthohol
    replied
    Re: Konica Minolta Bizhub C250i market place
    you can scan to O365 email but sharepoint is an app by itself afaik
  • Leifen
    replied
    Originally posted by Synthohol
    the i series supports O365, no app needed.
    How do you scan to O365 Sharepoint without app?
  • rrrohan
    replied
    thanks, using the installer program solved my issues
  • kingarthur
    replied
    as far as I know, you have to use the marketplace installer to remove devices, you'll need the IP, admin password, and the username/account that set it up, then select "Uninstall" marketplace.PNG
  • rrrohan
    replied
    yeah i did the same then when i attempted to log into marketplace again it said "keys already issued" and didnt log in
    Market-Place-error hosted at ImgBB — ImgBB (this is better size to read error)
  • Alex1
    replied
    Originally posted by rrrohan
    is removing yourself as admin the same as disassociating your marketplace link to device?
    I deleted the whole data on the machine, updated Firmware and installed movie data with no luck to the market place.
  • rrrohan
    replied
  • Alex1
    replied
    thank you however that wont answer my question.
    have you checked gateway and DNS and ping'd an outside web address successfully?
    if not, id start there.
    shotgun approach-->do a network initialization and use DHCP to verify connection to the outside world by pinging a web address in admin mode successfully.
    I'll give it a go and test the network however I think the network is fine. I'll let you know.
  • Synthohol
    replied
  • Alex1
    replied
    you need a good gateway and DNS to reach the outside world.
    in admin mode in network you can ping like google.com or msn or some other live site. if ping fails that machine is not on the internet. intranet maybe but not allowed outside the IP range.
    It was giving the same message in my workshop and at the customer's site when ever I select the marketplace app on the home screen.
  • Synthohol
    replied
  • Alex1
    replied
    does it link to a account? i thought it just connected to what ever marketplace account signed into it. ive logged in to 2 separate accounts of marketplace on one device with no problems
    It keeps saying can't connec, to check network connection however it's got a ethernet cable plugged into it.
  • rrrohan
    replied
    Originally posted by kingarthur
    As far as I'm aware, the previous owner needs to remove it from their account - probably should've been done before they gave it back
  • Alex1
    replied
    I thought maybe it's something that can be reset, then set up to the new customer, however the serial number being registered to the existing account it can't be done.
  • emujo2
    replied
    I'm a little confused..is the App already loaded into the marketplace?
    Here's what you should be doing..
    1. The customer needs to create a marketplace account.
    2. The customer needs to purchase the required app.
    3. You would log into the marketplace with the new account info.
    4. Go to purchased tab and download.
    5. Configure App in marketplace
    6. Sign into app after launching. You must have an established account to use..
