Developer in toner
  • wjurls
    replied
    Re: Developer in toner
    Maybe experiment with it? Take out a measured amount of toner (say 100 grams) and dispense it into a small plastic cup. Then run a magnet through it repeatedly until you no longer get any iron oxide sticking to it. Figure out the percentage of weight of developer to toner.
  • tsbservice
    replied
    Originally posted by jotunn
    Bear in mind, that color toners lasts for 26k pages, and black lasts for 29k - that's the main source of weight difference (in theory).
    This may be or may not be the case. In example TN324K lasts 28k and weight 547 grams and TN324M/C/Y lasts 26k and weights 513 grams, basically 2000 pages more are due 33 grams more in black cartridge. Both contain developer.
    TN216 C/M/Y weights 437 grams and TN216K - 524 grams, after some maths it appears toner in K cartridge should be 487 grams and and rest to 524 is developer - 37 grams developer per 524 cartridge.
  • jotunn
    replied
    K toner for C220 weights about 50 grams more than color toners so maybe that's the value I will need.
  • tsbservice
    replied
    MSDS will not help you in any way - the percentages described there are very generous (1-10%).
    True...percentages are between 2 - 20% (iron + manganese oxid). That means in grams between 10 - 100 grams.
    replied
    Hi folks, anyone knows how much developer is in one standart KM toner which weighs about 500 grams. Machines for example would be 4e, 8 series and latest.
    Will check later toner data sheets to find if any calculations can be approximated but any input is appreciated.
    It's a long time ago, but I believe in training the instructor told us it was around 10% developer in the toners
  • jotunn
    replied
    About 7 grams - based on simple calculations for C220 toners (because only black is mixed with developer), and it should be close enough to real value.
  • allan
    replied
    You have got me curious. What are you trying to do? The devtank will discard excess developer through the waste port. I would guess about a teaspoon full per bottle.
  • tsbservice
    started a topic Developer in toner
    Developer in toner
