Bizhub 350, soft switch settings
  • Hansoon
    • Sep 2007
    • 3385
    Bizhub 350, soft switch settings.
    Need a complete list with all possible soft switch settings for the Bizhub 350 please.
    Many thanks in advance.
    Hans
    nospam@rex-technika.com
  • kmcopier
    PSP
    • 183
    Check your service manual there is the complete list.
    Do you need a special soft switch? for something special?
    • Hansoon
      • Sep 2007
      • 3385
      Not in our Service manual. Perhaps the European version is different?
      Just like to have it for future purposes, but right now I like to know if the display of the electronic counters can be surpressed. Counters are showing wrong unlogical numbers differing greatly from the hardware counter which confuses the user.
      Hans
      • copytechman
        • Nov 2008
        • 943
        The latest firmware apparently fixes those issues, unless your nvram has been replaced.
        Regards!
        A.
        • kmcopier
          PSP
          • 183
          Yes copytechman is correct this bug is known. and fixed with the latest firmware.
          Kmcopier
          • Hansoon
            • Sep 2007
            • 3385
            I've heard about that bug too but am VERY hesitating to do a firmware update these days. Had from the same customer a Di-3510 with firmware issues which I could not solve until now. Customer believes I f#cked it up Don't want to mess this machine too by doing any upgrade as long as it is "working". Have still very limited experience with these models yet. Would be happy if I could conceal the electronic counters for the moment until I become a little less nervous about these machines and will be able to address the issue later on.
            Hans
            • pepper38_cnd
              Field Service Manager
              • Aug 2005
              • 1075
              The upgrade will fix it and your counters will come back to the propper state. Yes you are right if the firmware is really old you will have to do it instages to bring it to the latest.
              Now into Ip TV KODI Boxes
