Ikon CPP 650 / Bizhub C6500
  • Dedotch
    • Oct 2008
    • 40
    Does anyone have or know of a Friery that will run this machine. It is an Ikon CPP 650. I don't know if a Bizhub will work? Need a finisher too.
    Thanks, Scott
  • jma676
    Expert Tech
    • Mar 2009
    • 323
    Fiery S450 or IC-303 Check This Place: http://dk.ikon.com/support/downloads...hurecpp650.pdf
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
      If you're an IKON location, you can get a Creo for it as well.
      The Creo would need to be version 2.x to support the CPP650; 1.x won't work.
      You also have the option of the X3eTY2 "piggyback" controller, although it's not quite as powerful as the other RIPs.
      • jma676
        Expert Tech
        • Mar 2009
        • 323
        I`m not belong Ikon, Sorry I don`t have access to Controller Software.
        Fiery X3e TY2 is IC-408 Embeded Versions Controler, You Need Firmaware (G00-30) Actualizacion for use this Controller in 1.1 Version. This case for a Bizhub Pro C6500.
