c500 can't identified Creo IC-301
  • kmcopytech
    • Dec 2007
    • 141
    Creo IC-301 is connected C500 host,
    Turning On the IC-301 Print Controller and C500.
    Press "print button" can't display printer screen...??
    Any help...
    Thanks!
    My E-mail: kmcopytech@gmail.com
  • random
    If your talking about the print button on the copier, then no you won't see anything. This controller is supposed to have a screen, keyboard and mouse. If you press the scan button you should see 3 scan destinations.
    • kmcopytech
      • Dec 2007
      • 141
      1\C500 host can't display the status of print controller???
      2\Print Creo IC-301 test page after,C500 host didn't respond.
      3\Press "print button" can't display printer screen...??
      Any advices and helps!!!
      Thnks!
      Jack
      • buster68
        • Nov 2008
        • 181
        Make sure that the C500 has firmware version 14-CNU0.
        You may have to reboot the copier and the Creo several times before they connect. Touching the printer button on the copier will not show you anything, the creo is a completely different from the fiery.
        • Specilist KVN
          • Sep 2008
          • 79
          Yes, and make sure the C500 is FULLY booted up before you boot up the Creo.
          Also check the cable, the connecting on that model is not the most "reliable".
