Bizhub 500
  • poz31
    • Aug 2006
    • 86
    Bizhub 500
    But now is throwing a c2803
    Went into the counter area and look like this code 3 different options. The count abnormality #3 is the one showing the codes
    Does anyone know what this is referring to?
  • copytechman
    • Nov 2008
    • 943
    Thats an overtoned dev unit code.. enter service mode, reset it, try to run an auto toner supply... if thats a NG then you may want to change the dev and run a tcr adjustment, should fix 'er up... whats the dev / drum count.. makes a difference too..
    Regards!
    A!
