Does anyone know if the mod kits for resolving the C2152 error codes on the C203-252-353 and 353p are helpful in resolving the same codes on the C352. I don't want to waste time and money trying to put a mod kit into a machine that is not ment for. Thanks EMujo
C2152 errors on a C352
2152 code on these models are not the same as C253 on these models it can occur after the machine is transported the spring on the sensor actuator is not connected and the actuator is not retrning to home positiomwhen the primary rollers are engaged remove transfer belt when transporting these machines.
