This is Fixing Error. Low Temperature. Try:
Localize hole on right side of control panel. In hole is switch. Press it. Machine will restart. Enter “3” from the 10-Key Pad when dot appears at the center on the
left side of the screen while the start-up screen is being displayed.. You'll enter Initialize Mode. Press Trouble Reset. If error apears again, remove Fixing Unit and check lamp, thermo fuse or termistor. Good luck
