toners limited for bizhub c352
  • stu-stu-stu
    • Jan 2025
    Are the toners for the KM Bizhub C352 chipped? because they seem to be limited to a certain number of copies before they actually run out.
    Cheers
    Stu
  • KEVIN900
    Copier Ninja
    • Oct 2009
    • 200
    They have a chip, but the chips on the toner cartridges are there to prove to the copier that it's an OEM cartridge. Otherwise, they operate like any other copier. They add toner when the Toner/Carrier ratio gets low, and display "add toner" if the T/C ratio doesn't rise in due time.
    Kevin900
    • WmBruce
      Bizhub C352
      Toner is limited once the replace toner soon message appears and only the IUs can be re-chipped
