KonicaMinolta Bizhub C252 warm up time
  • Zesti
    • Jun 2009
    • 308
    Hi there,
    A newly installed Bizhub C252 have this problem. After going going in to sleep mode, it takes considerable amount of time (1-2 mins) to come online(Ready to Copy).
    Any help
  • copytechman
    • Nov 2008
    • 943
    Deep sleep? 1-2 min's isn't excess considering warm-up and stabilization processes on those boxes..
    Regards!
    A.
    • mabawser
      Tech
      • Sep 2009
      • 121
      In agreement with copytechman. That isnt a long time. If it causing problems adjust when it goes into sleep mode so it isnt going into sleep mode too soon. max -240 minutes
      • Zesti
        • Jun 2009
        • 308
        Thanks buddies.
        Is there any way to disable sleep mode...
        • copytechman
          • Nov 2008
          • 943
          Service mode -> system 1 -> no sleep
          Functions • To display the option of “OFF” for the Sleep Mode Setting screen available from
          Administrator Setting.
          Use • To display the option of “OFF” for the Sleep Mode Setting.
          NOTE
          • The sleep mode will begin in 48 hours even if it sets it to “OFF.”
          Setting/
          Procedure
          • The default setting is “Prohibit.”
          Permit “Prohibit”
          • KEVIN900
            Copier Ninja
            • Oct 2009
            • 200
            Also in Admin Mode -> System Settings-> Power Save-> then set to up to 4 Hours (240 minutes). Factory default is 15 or 20 minutes. set a bit longer, like 2 hours is more reasonable. I don't know if I'd want my machine to never turn off. Depends if the customer is a 24/7 operation, or a 9-5, Monday-Friday operation.
            Kevin900
            • Zesti
              • Jun 2009
              • 308
              Thanks Copytechman,
              Will try that.
              The customer is a 24/7 operation and already set the sleep to 240 min. but they want immediate response from the machine, especially first time in the morning....
