Bizhub C550 wich cant see finisher.
  • ReoNeo
    • Dec 2008
    • 25
    Hello... Have a quistion regarding Bizhub C550.
    The problem is that the C550 cant see that a finisher Fs-517 is attached.
    Hope that someone can give me a hint regarding this issue.
  • emujo
    • Jun 2009
    • 3009
    The FS-517 is not recognized by the copier.
    Description:
    FS-517 finisher is not recognized.
    Solution:
    CAUSE: Outdated firmware. Firmware version 6B or higher is required to support the FS-517 or DIPSW 1 & 2 are set to OFF.
    SOLUTION: Upgrade the copier firmware to version 6B or higher. Also make sure DIPSW 1 and 2 on the TRCB is set to ON.
    Emujo
    • MR CLEAN OC
      bad dc power supply.
      • ReoNeo
        • Dec 2008
        • 25
        Thank you, changed the power and ok.
